Ra-01SCH
Characteristic:
Support FSK, GFSK, and LoRa® modulation mode
Support frequency range 803MHz~930MHz
The operating voltage is 3.3V, the maximum output power is + 22dBm, and the maximumworking current is 120mA
The RX state has low power consumption characteristics, the lowest RXcurrent is 4.2mA, and the standby current is 0.6mA
High sensitivity: as low as-129dBm
Support for the expansion factor SF5/SF6/SF7/SF8/SF9/SF10/SF11
Small volume double-column stamp hole patch package
The module adopts an SPI interface, half-duplex communication, and with CRC, a packet engine of up to 256 bytes
The antenna interface is compatible with stamp hole /through-hole and IPEX, whichsupport more scheme selection
