Ra-09
Characteristic:
Adopt SMD-48 package
Support frequency: 410MHz-525MHz
Working voltage is 3.3V, and the theoretical maximum transmit power is +22dBm
High sensitivity: -140dBm @125KHz SF12
Support spread spectrum factor SF5/SF6/SF7/SF8/SF9/SF10/SF11/SF12
Embedded memory,256KB FLASH,64KB RAM
Support LoRa/(G)FSK/BPSK/(G)MSK modulation
The antenna interface is a half-hole pad and an IPEX connector, which supports a varietyof
external antenna connections and supports more program selection
Support multiple sleep modes: depth sleep current is low to 0.1uA
