Ra-09H
Characteristic:
SMD- 48 package
Supported frequency bands: 803MHz- 930MHz
Working voltage is 3.3V, theoretical maximum transmit power +22dBm High sensitivity: -140dBm @125K H z SF12
Support spreading factor SF5/SF6/SF7/SF8/SF9/SF10/SF11/SF12
Embedded memory, 256KB FLASH, 64KB RAM
Support LoRa/(G)FSK/BPSK/(G)MSK modulation
The antenna interface is a half-hole pad and IPEX connector, which supports a varietyof external antenna connection methods and supports more solution selections. Supports multiple sleep modes: deep sleep current 0.1μ A
It can be widely used in smart meters, supply chain and logistics, homebuilding automation, security systems, remote irrigation systems and other scenarios.
